How to Rip DVD for BlackBerry with DVDFab DVD Ripper?
05/27/2020
BlackBerry once was one of the most prominent smartphone vendors in the world, but it has lost its dominant position in the market nowadays due to the success of the Android and iOS platforms. But in consideration of its great sales volume, there must be some people worldwide who are still using BlackBerry.
If you are a Blackberry user and want to watch your DVD movie on it, you can use DVDFab DVD Ripper to rip or convert DVD to BlackBerry. DVDFab DVD Ripper provides BlackBerry profiles for you to rip DVD to Blackberry effortlessly. The following is a detailed guide to show you how to rip DVD to BlackBerry with DVDFab DVD Ripper.
Step 1: Load the source
Run DVDFab 10, go to Ripper module and load the source.
Step 2: Choose a BlackBerry profile
Navigate to the profile library on the top left corner of the main interface and choose Device> BlackBerry. Here are three BlackBerry profiles, and you can choose the one you need. Here I take Z10 as an example.
Step 3: Customize your video
After the source is loaded in, the longest title, namely the main movie, will be selected by default. But here you can choose other titles. You also can choose the chapters, audio tracks, subtitles, and define the name of the chosen title. If you want, you can also click the “Advanced Settings” icon to customize your settings and click the “Editor” icon to edit the video.
Step 4: Select a directory and start the ripping process
Click the "folder" button to select a directory to save the output video. And then you can click the "Start" button to start the process of ripping DVD to BlackBerry.
If there is no the BlackBerry model you want to convert to, you can use DVDFab DVD Ripper to convert DVD to the video format supported by your BlackBerry.
For people who also want to convert video to various video/audio formats, you can use DVDFab Video Converter — the fastest and most full-featured video converter tool.
